Printer Control¶
Bambuddy provides control over various printer settings and features directly from the web interface.
Print from Printer Card¶
Start prints directly from any printer card — no need to navigate to File Manager first.
Print Button¶
A green Print button appears on each printer card when the printer is idle:
- Click the Print button at the bottom of the printer card
- A file upload modal opens — select a
.gcodeor.gcode.3mffile - The file is automatically uploaded to your library
- The Print Modal opens with the printer pre-selected
- Configure filament mapping and print options, then click Print
The printer selector is hidden since the target printer is already known.
Drag & Drop¶
Drag a sliced file directly onto any printer card to start printing:
- Drag a
.gcodeor.gcode.3mffile from your computer onto a printer card - A green "Drop to print" overlay appears (or red "Printer busy" if unavailable)
- Drop the file — it uploads to your library automatically
- Configure and print
Accepted File Types
Only sliced files (.gcode and .gcode.3mf) are accepted for drag-and-drop printing. Other file types will show an error. Use the File Manager to upload non-printable files.
Printer Compatibility Check¶
Both flows automatically check if the file was sliced for a compatible printer model. If the file's sliced_for_model metadata doesn't match the target printer, you'll see an error and the file is removed from the library.
Requires the Printer Control permission (printers:control).
Printer Information¶
View detailed printer information from the three-dot menu on any printer card.
Click Printer Information to see:
| Field | Description |
| Model | Printer model name |
| Status | Connection status (online/offline) |
| State | Current state (idle, printing, paused, etc.) |
| IP Address | Network address (copyable) |
| Serial Number | Hardware serial (copyable) |
| WiFi Signal | Signal strength with quality indicator |
| Firmware | Current firmware version |
| Developer Mode | Whether LAN developer mode is enabled |
| Nozzle Count | Number of nozzles |
| SD Card | Whether an SD card is inserted |
| Auto-Archive | Whether auto-archiving is enabled |
| Print Hours | Total accumulated print hours |
| Location | Configured printer location |
| Added | Date the printer was added |
Print Job Controls¶
Control active print jobs directly from the printer card:
Stop Print¶
Cancel the current print job:
- Locate the Stop button () on the printer card during printing
- Click to stop the print
- Confirm in the modal dialog
- Print is cancelled and printer returns to idle
Permanent Action
Stopping a print cannot be undone. The print must be restarted from the beginning.
Pause / Resume¶
Temporarily pause and resume printing:
| Button | State | Action |
| Pause | Printing | Pauses the print, filament retracts |
| Resume | Paused | Resumes printing from where it stopped |
To pause/resume:
- Click the Pause button during an active print
- Printer pauses and displays "Paused" status
- Click Resume to continue printing
When to Pause
Use pause to inspect the print, remove debris, or insert objects for encapsulation.
Clear HMS Errors¶
Dismiss stale HMS errors directly from the HMS error modal:
- Click the HMS indicator on the printer card to open the error modal
- Review the listed errors
- Click Clear Errors to dismiss them
The clear command sends clean_print_error via MQTT and immediately removes errors from the UI. This is useful after print cancellation or transient events that leave print_error values behind.
Clear Plate¶
When a print finishes or fails and there are queued prints waiting, a "Clear Plate & Start Next" button appears on the printer card. Clicking it confirms that the build plate has been cleared, allowing the queue scheduler to start the next print.
Requires the Clear Plate permission (printers:clear_plate). This is a separate, more granular permission than printers:control, allowing admins to grant plate-clearing ability without full printer control access.
Confirmation Modals¶
All print control actions require confirmation to prevent accidental clicks:
- Stop: "Are you sure you want to stop this print?"
- Pause: "Are you sure you want to pause this print?"
- Resume: "Are you sure you want to resume this print?"
Toast notifications provide feedback after each action.
Skip Objects¶
Skip individual objects during a print without stopping the entire job.
When a print starts, Bambuddy extracts object information from the 3MF file. You can then skip any object that's failing or that you no longer need.
Using Skip Objects¶
- Click the Skip button (top-right of printer card) during printing
- A modal appears showing:
- Preview image with object ID markers overlaid in a grid
- Object list with large ID badges and names
- Info banner explaining to match IDs with your printer's display
- Click Skip next to any object you want to exclude
- The object will be marked as skipped and won't be printed
Skip Objects Modal¶
| Element | Description |
| Preview image | Shows print with ID markers overlaid |
| ID badges | Large numbered badges matching printer display |
| Object list | Names with skip buttons |
| Skipped count | Badge on button shows how many skipped |
Object Display¶
| Status | Appearance |
| Active | Green ID badge, Skip button visible |
| Skipped | Red ID badge, strikethrough text, "Skipped" badge |
Layer Requirement¶
Wait for Layer 2
Skip is only available after the first layer is printed. This is a printer limitation - the printer needs to establish object positions before allowing skips.
A warning message appears in the modal when on layer 0 or 1.
Requirements¶
For skip objects to work properly:
- Enable Exclude Objects in your slicer (Bambu Studio / OrcaSlicer)
- Go to Other → Exclude objects
- This ensures each object gets a unique ID
- Objects must be properly separated in the slicer
- Clone/array objects may share IDs unless exclude is enabled
- Print must have 2 or more objects
Matching Object IDs
The printer's display shows object IDs on the build plate visualization. Match these numbers with the IDs shown in Bambuddy's modal to identify which object is which.
When to Skip
Use skip objects when:
- An object is failing but others are printing fine
- You want to cancel part of a multi-object print
- A support structure or test piece is no longer needed
Cannot Undo
Skipping an object is permanent for the current print. The object cannot be un-skipped once marked.
Chamber Control¶
For enclosed printers (X1 series, H2 series), control the chamber environment:
Chamber Temperature¶
- View current chamber temperature
- Set target temperature (if supported)
- Monitor heating/cooling status
Chamber Light¶
Toggle the internal chamber LED directly from the printer card.
Location: Light button next to the camera button at the bottom of the printer card.
| State | Appearance |
| On | Yellow background, filled bulb icon with rays |
| Off | Gray background, outline bulb icon |
To toggle:
- Click the light button at the bottom of the printer card
- Light state changes immediately (optimistic update)
- Toast notification confirms the change
H2D Dual Lights
On H2D printers with dual chamber lights, both lights are controlled together.
Fan Controls¶
Monitor and adjust cooling fans directly from the printer card.
Real-Time Fan Status¶
The Controls section displays compact fan badges showing real-time speeds:
| Fan | Icon | Color | Description |
| Part Cooling | Cyan | Cools printed layers (0-100%) | |
| Auxiliary | Blue | Controls chamber airflow (0-100%) | |
| Chamber | Green | Exhausts hot air (0-100%) |
Badges are always visible with dynamic coloring:
- Active (colored icon + text): Fan is running
- Inactive (gray icon + text): Fan is off, shows 0%
Part Cooling Fan¶
- View current speed (%)
- Adjust during print if needed
- Auto-controlled by slicer normally
Auxiliary Fan¶
- Controls airflow in the chamber
- Helps with certain materials
- Can be adjusted manually
Chamber Fan¶
- Exhausts hot air from enclosure
- Important for high-temp printing
- Auto-controlled based on chamber temp
:material-nozzle: Dual Nozzle Support¶
For dual-nozzle printers (H2D, etc.):
Nozzle Status¶
View both nozzles:
- Current temperature
- Target temperature
- Heating status
Nozzle Selection¶
See which nozzle is active during printing.
Power Controls¶
Control printer power state:
Power Switch¶
If a smart plug is configured:
- Power On - Turn printer on
- Power Off - Turn printer off
- Status - View current power state
Auto Power Off¶
Configure automatic shutdown:
- Enable Auto Power Off in settings
- Set Cooldown Temperature threshold
- Set Cooldown Time delay
- Printer powers off after print completes and cools
Print Settings Override¶
During an active print, you can adjust:
| Setting | Adjustable? |
| Part cooling fan | |
| Chamber light | |
| Pause/Resume | |
| Cancel |
Limited Changes
Not all settings can be changed mid-print. Temperature and layer settings are locked.
Chamber Management
For ABS/ASA, keep the chamber warm. Open doors for PLA to prevent heat creep.
AI Detection Value
AI detection has saved countless prints. The small time cost is worth the protection.
Regular Calibration
Run bed leveling from the printer's touchscreen after major moves or every few weeks for best first layers.
