Bug Report
Submit bug reports directly from the Bambuddy UI without leaving the application.
The in-app bug report feature provides a quick way to report issues:
  • One-click access — Floating bug button in the bottom-right corner
  • Screenshot support — Upload, paste from clipboard, or drag & drop images
  • Automatic diagnostics — System info and debug logs collected automatically
  • Privacy-first — All sensitive data is sanitized before submission
  • GitHub integration — Reports create GitHub issues automatically
Submitting a Report
  1. Click the red bug icon in the bottom-right corner of any page
  2. Describe the issue — What went wrong? Steps to reproduce?
  3. Add a screenshot (optional) — Upload a file, paste from clipboard (Ctrl+V), or drag & drop an image onto the upload area. Images are automatically compressed to JPEG.
  4. Add your email (optional) — If provided, your email will be included in a collapsed section of the GitHub issue so the maintainer can follow up.
  5. Click Submit
What Happens After Submit
After you click Submit, Bambuddy automatically:
  1. Enables debug logging temporarily (if not already enabled)
  2. Queries all connected printers for fresh status data
  3. Waits 30 seconds to collect diagnostic logs (a countdown timer is shown)
  4. Sanitizes all logs — Removes printer names, serial numbers, IP addresses, credentials, and other sensitive data
  5. Submits to GitHub — Creates an issue with your description, screenshot, system info, and sanitized logs
  6. Restores normal logging if debug was not previously enabled
Data Privacy
The bug report includes a detailed, expandable privacy notice explaining exactly what data is collected.
Included in the report
  • App version, OS, architecture, Python version
  • Database statistics (counts only)
  • Printer models, nozzle counts, firmware versions
  • Connectivity status
  • Integration status (Spoolman, MQTT, Home Assistant)
  • Non-sensitive settings
  • Network interface count
  • Docker details
  • Dependency versions
  • Sanitized application logs (last 200 lines)
Never included
  • Printer names or serial numbers
  • Access codes or passwords
  • IP addresses
  • Email addresses (except your own, if you provide it)
  • API keys or tokens
  • Webhook URLs
  • Hostnames or usernames
Bug reports are submitted through a secure relay service on bambuddy.cool. This relay:
  • Holds the GitHub API token server-side (never shipped in the application)
  • Uploads screenshots and log files to GitHub
  • Creates issues with appropriate labels
  • Rate-limited to prevent abuse (5 reports per hour)
Your Bambuddy instance never needs a GitHub token — the relay handles all GitHub communication.
